Commodore Vt water leak
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by Boba, Dec 3, 2012.
  1. Boba
    Boba New Member
    Albury
    Vt commodore
    Can hear the water boiling, then leaking under the left head light. Took it to the mechanics a few weeks ago and he replaced a gasket or something (Not very knowledgeable with cars) and it still leaks. New radiator cap is a good idea?
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    That will be coming from the overflow hose in the reserve tank (the bottle thing with a yellow cap). A new radiator cap should should fix it. But you should first make sure that the system has been bled so there is no air in there.
  3. vxs93
    vxs93 Member
    2002 VX s-pac manual
    lol im definitely not an expert but if i were you i would check the whole engine bay for leaks. check all the hoses and seals and make sure you have enough coolant. open the radiator cap (when engine is cold) and add some pre mixed coolant or de-mineralised water until it is full. I would change the radiator cap also as if it is faulty it will make the overflow tank leak. If you are still having problems take it down to another mechanic, better to pay someone than risk damaging your engine or other components.
  4. Boba
    Boba New Member
    Albury
    Vt commodore
    How do I bleed the system?
  5. accentstencil
    Eschol Park, Sydney
    Get the engine up to operating temperature, then slightly undo the bleeding screw on top of the thermostat housing and air should escape. Keep opening and closing the screw until there is a steady steam of coolant with no air. Be careful not to scald yourself.
    If you don't know where the thermostat housing is, follow the top radiator hose to where it attaches to the engine and that is it.
  6. Boba
    Boba New Member
    Albury
    Vt commodore
    Is that the thick hose? About half a meter if that
  7. accentstencil
    Eschol Park, Sydney
    Yes it is.
  8. Boba
    Boba New Member
    Albury
    Vt commodore
  9. accentstencil
    Eschol Park, Sydney
    Yes, but only about half a turn or so.
  10. Boba
    Boba New Member
    Albury
    Vt commodore
    Ok thanks heaps. Will get a new cap now and try this and post back
  11. accentstencil
    Eschol Park, Sydney
    Try bleeding it first, you might not need a new cap.
    After bleeding check the coolant level in the radiator when the engine has cooled down and top up if necessary.
  12. Boba
    Boba New Member
    Albury
    Vt commodore
    Oh yeah, does the car need to be on
  13. accentstencil
    Eschol Park, Sydney
    Yes, on and at normal operating temperature.
  14. Boba
    Boba New Member
    Albury
    Vt commodore
    OK, tried that but couldnt get the screw to budge
  15. accentstencil
    Eschol Park, Sydney
    Try multigrips.
