[LS1] Comp Cams 232/234
Jolls
Donating Member
Murrumbateman
VY SS Ute (Jimi Hendrix)
Hi Team
I recently wrote off my VZ ute after hitting a roo and was in need of a new shell.
I just purchased a VY SS Ute that was supposedly running 12's as an auto. The slush box and diff died under the stresses.
3/4 of a manual changeover has been completed for her to run a T56 with an Eaton True Trac and Dana 3.9s
What I inherited was an LS1 with ported and shaved heads running a Comp Cams 232/234. The cam specs are:
  • Rpm operating range 2400 - 7200
  • Duration advertised Inlet 281°, Exh 283°
  • Duration advertised @ .050" Inlet 232°, Exh 234°
  • Valve lift with 1.7 rocker Inlet .598", Exh .598"
  • Lobe separation angle 112°
I'm not unhappy with the purchase at all. I know what I am sitting on; I just don't have any experience running a race style cam. Do you think this will be streetable or should I change the cam out for something else?
Your wisdom and advice would be greatly appreciated.
Cheers n Beers
Jolls
Immortality
Staff member
Sth Auck, NZ
Run it and find out. What some people will find acceptable others will not. 3.9 gears should make it more manageable.
Jolls
Donating Member
Murrumbateman
That's the current plan. It will clearly runs and could be workable; but, I would prefer if someone with a similar setup could provide some advice related to their experience. If it is an utter pig I would prefer not to put it together just to pull it back out.
07GTS
Australia
VEGTS BUILT BLOWN E85
will sound angry and need good tuner for street use, with the manual may get a bit bucky if not right down low but if sorted out should be fine
Jolls
Donating Member
Murrumbateman
Thanks 07GTS
was hoping to hear something positive. I'll give it a crack and report back once I have it all mated up. Need to grab a clutch kit to match the output now and we should be sorted for the build.
Cheers n Beers
Jolls
Immortality
Staff member
Sth Auck, NZ
You could also play around with the cam timing. Advance it 2-4° over the recommended installed position. That will close the intake valve a bit earlier and improve low end a bit over the cost of high rpm/peak power performance.
Jolls
Donating Member
Murrumbateman
Thanks Immortality, I will try it as it is and see where we go from there.
Cheers v Beers
Jolls
blackvxss
47
radelaide
VF SS, VE SS ute, VZ SS crewman, VYSS, VX SS, VTSS
Had that cam in my manual sv8 with 3.9 gears. Installed cam myself. Used as a daily drove fantastic sub 10l/per hundred on highway and around 14 in town. You need a good tuner with heaps of experience. Never had low rev issues or bucking etc.
Jolls
Donating Member
Murrumbateman
Thanks mate that is the news I want to hear. I feel much more positive hearing that news.
Cheers n Beers
Jolls
