whats wrong with fish eyes?
Or you could do what ive seen done. A filed down 15A plug to fit a 10A socket.
Dont do this. Its stupid.
Shhh, I made up a 300mm extension cord, 10A one side and 15A the other end.
I just unwired the 15amp plug on my compressor and slammed a 10amp plug on. But I only use it down in the shed where the powerboard is rated to ~40amps, we just forgot to install 15amp plugs.
You realise all the above advice can burn the op's house down yes??!
Unless he has a modern rcd protected type c 16a breaker in good working order your risking overheating your cable and it melting or igniting..
Believe me I've fixed this from backyard welders many times
Honestly if your serious about spraying your own car or others stuff get a 15a gpo installed, not that expensive, odds are less than the cost of your compressor and then you aren't risking a major asset like a house over some dodgy wiring.
Also good thread tho as I'm researching the same thing
Thats why I added the last line.
Yes I will add the the OP shouldn't do this unless they have a setup that can run this safely. In my case I have plenty of leeway.
