Computer swap fron sedan to tonner
Discussion in 'VY Holden Commodore (2002 - 2004)' started by corrupt, May 17, 2010.
  1. corrupt
    corrupt New Member
    vy tonner
    Gday I have a vy v6 tonner that eats allot of fuel, It likes to rev, just gently accelerating it will rev to 2500rpm before changing gears, doesn’t change into 4th until 70-80km/h and the torque converter doesn’t lock up till just over 110km/h, pushing the power button makes it rev even more. I brought a sedan computer of ebay and didn’t even think about the coded keys, so my Question is can i just swap over the chip inside the ecm to make it behave like a sedan and still keep using my original keys??
    Thanks Shane
  2. one_and_only2004
    one_and_only2004 Turbo L98 FTW
    Regional NSW Australia
    Z Series Thunder Utility - Turbo
    I think you can get the new computer reprogrammed to fit your BCM. Holden should be able to do it.
  3. corrupt
    corrupt New Member
    vy tonner
    Thanks but I am trying to avoid giving more money to my local Holden Stealership
  4. one_and_only2004
    Well i'm afraid you're fresh out of luck then - the BCM, the key, the computer - they all have to be programmed to talk to each other.
  5. corrupt
    corrupt New Member
    vy tonner
    bummer...thanks
  6. 0081
    0081 New Member
    VY s m5 supercharged
    I think you should be able to remove the chip and put in your other computer with you changing any codes but its soldered in so you will have a bit of work on your hands to get it out
  7. one_and_only2004
    Nope, even if you swap over just the chips it still won't work. They need to be specifically programmed for that VY - Chiptorque in Nerang told me about this.
