connecting amp to ve original radio
Discussion in 'Car Audio' started by t0m3kkk_ve, Dec 8, 2009.
  1. t0m3kkk_ve
    t0m3kkk_ve New Member
    VE OMEGA
    hi there just wondeirng if it is possible to connect an amp to a ve orignal radio...
    seen it can be done with the vy/vz and was worndering if anyone would be able to tell me how to do it with the ve
  2. acarmody
    acarmody Donati..Whoa Green
    VX Berlina
    Yes it can. Phreddy can hook you up with an RCA mod. ASR Audio & Electronics
    Or alternatively you can use a LOC but it won't be as good as hard wiring in some RCAs.
  3. mi04se1
    mi04se1 need for speed
    White Lake, MI
    Pontiac G8GT
    Use a line out
  4. holdenboy
    holdenboy Custom Car Stereo Systems
    Nelson Bay NSW
    VR Wagon
    If youre just wanting to power a sub off the amp youre connecting up, then a LOC (line out converter) will work fine. Ive used even the cheap Jaycar ones in VEs without a drama. All you need to do is remove the underside of the parcel shelf and tap into the rear speaker wires (you can still leave the rear speakers connected), then run these wires to the LOC.....from there youve got RCA outputs to the amp. If you want a power souce to turn the amplifier on / off with the ignition you'll need to remove the drivers side of the centre console to access an unused handsfree kit plug, this has accessories power in it so just attach a wire to that and run it to the amp. The wire is in a white plug, its brown / yellow.
    If youre wanting to run full range speakers (like splits) off the amp i suggest you either get Phreddy from ASR (site sponsor) to mod your unit to have RCA outputs or spend a few hundred on a very good quality line out converter, like the Rockford 3sixty.
  5. Unit_01
    Unit_01 New Member
    Brisbane, QLD
    MY9.5 VE SV6 M6
    Hi there.
    I'm trying to put my LOC in and am having trouble finding the rear speake wires that I'll be tapping into.
    I've got a MY09.5 VE SV6 so not too sure if I've got speakers in my rear parcel shelf.
    And which wire should I tap into so that the amp turns on itself when the car is on?
    Cheers.
  6. Lamby22
    Lamby22 Donating Member
    South Australia
    VY SS
    Unit 01: Not sure about your speaker question but as for what wire tap into any accessory circuit, cigarette lighter etc.. I think should work?
  7. holdenboy
    Nelson Bay NSW
    VR Wagon
    Not sure on the speaker wires either.....arent the speakers in the rear doors?
  8. Unit_01
    Unit_01 New Member
    Brisbane, QLD
    MY9.5 VE SV6 M6
    Yeah there's speaker in the rear doors...
    I can just tap into that yeah?
  9. holdenboy
    Nelson Bay NSW
    VR Wagon
    Yep, you'll need to tap into the wiring before it goes into the door, just below the seatbelt bolt in the B pillar is a good spot, just make sure youve got the right wires though ;)
  10. Luke0011
    Luke0011 Car Audio Installer
    VZ Berlina 2005
    MMM interesting, because the phone kit plug is behind the glovebox and the accessorie wire is a brown wire, i dont think there is another under the centre console holden boy unless im wrong, but he is talking about a VE commodore..
  11. holdenboy
    Nelson Bay NSW
    VR Wagon
    Hmm, well it might not be the phone kit plug then, but this is definitely a spare plug under the stereo on the drivers side.....not doing anything.
    Havent done a handsfree kit a VE yet, but thanks for that info.....will make it easier when im trying to figure out why none of those wires in that plug are mute, lol.
  12. Unit_01
    Unit_01 New Member
    Brisbane, QLD
    MY9.5 VE SV6 M6
    Would you care to give some info on what colours I should tap into please :beer chug:
  13. holdenboy
    Nelson Bay NSW
    VR Wagon
    Left Rear - Yellow/Red(-) Brown(+)
    Right Rear - Light Blue(-) Dark Blue(+)
  14. Unit_01
    Unit_01 New Member
    Brisbane, QLD
    MY9.5 VE SV6 M6
    Thanks buddy.
    F'ing legend haha :beer chug:
    And with the remote wire, I'll tap into the accesory wire yes?
    If I don't run my remote wire yet, how does the amp turn on/off?
  15. Adza75
    Adza75 Active Member
    VFII SSV Redline
    The plug beside the drivers seat is *apparently* the pre-wiring for the amp in the SSV models which already have subs in the parcel shelf. Does this plug just have an accessory feed or is it an actual on/off feed from the head unit?
  16. Luke0011
    VZ Berlina 2005
    No it is definatly not pre wiring for a amplifier, it pre wiring for an ashtray, i just fitted one today.
    The mute wire in the white connector behind and to the left of the glovebox is white and the audio inputs are light blue and orange/ damm forgot th trace wire, but its next to the light blue wire.
    brown is accessory and orange/ dam forget the trace wire, its the bigger of the orange wires in that connector.
  17. Luke0011
    VZ Berlina 2005
    Yes it is an accessory feed, there is no on/off feed from the headunit. It turns on via GMLAN data bus.
  18. Adza75
    VFII SSV Redline
    The ash tray wiring is in the centre console area... I'm talking about the one next to the drivers door... there's another thread on it I'll dig it up.
  19. holdenboy
    Nelson Bay NSW
    VR Wagon
    Yeah that wire dosent turn on / off with the stereo, so when you turn the key off and the radio still stays on the amp will turn off......good if your running a high powered amp and sub, it means when you turn the car off you dont risk running the battery flat.
    Although, now i know where the "actual" handsfree plug is i'll be using that from now on. Thanks Luke.
  20. Luke0011
    VZ Berlina 2005
    No worries and prewiring plug does not make sense as with the woofers, the 4channell out from the headunit goes to the amp and it powers all speakers in the calais, clubsport, senetor, caprice, and so on. It cannot be a pre wiring plug because the headunit would be already connected to the speakers so it wouldnt be a simple patch loom.
