conrod and main bearings
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by sebstenator, Jun 20, 2008.
  1. sebstenator
    sebstenator Burn
    VN SS 5.0
    i was just wondering how i would go about replacing my conrod bearings and main bearings.
    would it be possible just by removing the oil sump and doing it from underneath?
  2. Cheap6
    Cheap6 New Member
    VP Exec
    Assuming the crank is OK, yep but awkward. Conrod bearings are easy, one at a time. With mains, again one at a time, the trick is to use a split pin inserted into (each) oil hole to rotate the block side of the bearings into place using the crank. It's up to you whether or not you check the clearances; Plastigage is the only way that I know of to do that without pulling the crank.
  3. 89berlina
    89berlina Member
    Gladstone, Queensland
    1989 VN Berlina
    Some soldar instead of Plastigage also does the trick.
  4. 383 hatch
    383 hatch Well-Known Member
    Cowes, Phillip Island
    How does solder tell you what size the clearances are?? Plastigauge comes with measurements on the package so you can compare them and see what size the clearances are.....How do you do that with solder?? If you cant get plastigauge, you shouldn't be building an engine!
  5. Pub247
    Pub247 Well-Known Member
    Melbourne S.E.
    Ford Fairmont
    LOL just read this thread how'd i miss it. Love to know where you can get solder that is 1 thou thick would be great for this nano computer i'm building.
    Also if you can fit solder in your clearances then i suggest you stay away from engines
  6. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    yeh before it blows up jks:whistling
