Conversion of an automatic to a manual.
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Enigma03, Apr 27, 2011.
  1. Enigma03
    Enigma03 New Member
    Redbank Plains Queensland
    Holden Commodore VP
    Hi i own a VP commodore and would like to convert it from an automatic to a manual. Is this process a difficult one? If it is relatively easy what part's would i need beside's the manual gear box?
  2. Reaper
    Manual box, fly, clutch, clutch cable, pedal box, patch loom for the shifter (normally comes with the box), tailshaft and about 3/4 day of your time. Straight forward job. Just a tip though, fully take out the steering column to change over the pedal box - it's just much easier that way.
    Reaper
  3. hi_ryder
    hi_ryder Donating Member
    Pascoe Vale South, MEL
    v6 v8? when i sold the conversion kit off my wrecked vt v6 i sold the drive shafts, transmission (with clutch, clutch fluid res bottle, and flywheel), engine loom (with manual ecu), floor pedal assembly, shifter boot surround, and youll need the manual radiator with the different hoses i think. some of this wont apply to the vn/vp but its something to think about... the next posts will fill in the gaps...
  4. Enigma03
    Enigma03 New Member
    Holden Commodore VP
    Pedal box what do you mean by that? Sorry but this will be my first major job like this so I'am after as much info as i possibly can attain about the job as for i do not want do f the car up.
  5. Enigma03
    Enigma03 New Member
    Holden Commodore VP
    Hi_ryder
    It's a V6 3800 series one just after as much info as possible before i get stuck into the job, as for this is my first major job.
  6. Reaper
    VT had a getrag box and hydraulic clutch actuator. VN-VR have a clutch cable and thus is somewhat simpler. You use the same ECU on manual/auto with a VP although it's probably recommended to get a manual tune. Radiator etc is exactly the same on a VN/P - just disconnect any transmission cooler lines if it has them.
    The pedal box bolts to the firewall under the dash. Auto has 2 pedals, manual has 3.
    Reaper
  7. wraith
    Demonicaland
    VX V6 Berlina. 2003 VW Passat
    Time and effort vs gain is minimal. If your bored go for it other wise don't bother. Every one seems to make it seem easy but it's a lot messing around just for a 3rd pedal and stick shift.
  8. Enigma03
    Enigma03 New Member
    Holden Commodore VP
    It's more for the fun in my ride as for I'am way over auto's and mis shifting down gear's and hearing the beautiful note from the engine.
  9. hi_ryder
    im a luxury car kinda guy, manuals dont do it for me. im a lazy yank, and the calais and statesmans are the closest thing i could get to a cadillac. i can see the fuss with manuals if your gonna build a tire fryer....
  10. mischa
    mischa Donating Member
    Ruse, NSW
    355 VN GRP A REP
