88GreenVN
Next Exit Left
- Jun 12, 2006
- 6,795
- 136
- 63
- Age
- 60
- Location
- Surprise, Arizona
- Dodge Ram Van 1500 5.2 V8
Just ran the test mode, Displays the following
1ST MODE
1. Speed 0 Km (digital speedo - needs to be set every time you start the car tho)
2. Fuel 1.0
3. BTN ---- (this is a test for your buttons it shows a 0 when you press the set. + or - button)
2ND MODE
1. V 12.0 (volts from battery and should be up around 13 ish)
2. FUEL 2:61
3. BTN ----
3RD MODE
All displays on LCD s come up, all working and readable Dash beeps and all warning lights light up eg fuel, SPD Park, and water. Except Speedo First 2 digits are a cross between L L and E E take the top line off the E and thats what they look like. Still no LCD lights. Is this unit faulty?????
The lights not working are inside the trip computer. Cluster needs to come out and lens off. Unclip the tag out the bottom of the trip computer (gental here) and then undo the 2 screws holding it in (from the front). Once out the trip computer has 3 screws hoding it in (some of the corner plastic may be gone or cracked - can be super glued back on if needed) and the white lid holding the 3 lcd screens flips over. You will find 4 globes in here that twist out. some times they come back to life with a little tap with 1 finger on the front panel most time not. If you take the trip on it's own and plug it into the 4th plug under the dash and turn the ign on it will light up any globe that has life (with light tap on the front) left in it. If none work then you may want to get 1 from Holden ($16) or similar globe supplier.
