PUR53
- Sep 7, 2012
- 6
- 0
- 0
- Age
- 37
- Location
- Gympie
- VH SL 4.2/A3 - VR 3.8/A - VP 3.8/A - AE82 Corolla
I'm about to start a build and I'm thinking about converting my VP to VR front suspension and VT brakes.
I want to scrap my VR and use as much as possible to update and make my VP safer and easier to work on. I want to use from the VR; control arms, shortened heavy duty struts, adjustable sway bars, sealed bearing hubs, castor rods and springs. I would then use a VP style adjustable strut top. I also want a front VT brake upgrade kit (plus a 1" master cylinder) and urethane bush kit.
I guess I'll get asked why I want to do this so I'll explain. So I'm aiming to build a Vortech blown V6 pumping 14psi and making up to 300rwhp so I'm building a car that can corner like it's on rails and stop on a dime.
My VP is going to be built as a mildly worked daily with no air con or power steering. I've got a V1 Vortech that I'm custom mounting on the drivers side, I'm running a manual steering rack so I'm going to use the empty space for my charger pulley. From there I'm running a small intercooler under the bonnet, I'm going to move the radiator back a few inches and make a OTR air filter box/intercooler duct and straight into the intake. I'm doing this because i'm after throttle response and have a sleeper. The motor will remain standard bar a few safety and reliabity upgrades; high ratio roller rockers, valve springs, engine oil cooler, double row timing chain, high pressure oil pump, ecotec sump, fuel system, exhaust and an extensive tune.
Lastly any ideas (pros and cons) on transmission??? I'm leaning towards a professionally built manualized auto with a 3000rpm stall converter, I'm not keen to be swinging off a heavy duty clutch everyday and I want something that will last and stand up to a bit of punishment. Also I have 3.23 and 3.45 diff gears.
