[LS1] Coolant drain plug
H1GHROLLR
CHEMICALLY SUPERCHARGED
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
hi people does anyone know where the coolant drain plug is to drain the
block on the ls1. . .just taking of the bottom hose wont empty the block
will it??
Lumps of cheese
welcome to the machine
44
Warrnambool
83 vh sle, 4x4 hilux, 03 monaro, 07 nightrain
I just took off the heater hose and flushed it through with the garden hose until it was clear, that way you get it all out.
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
which hose did you take off mate there are heaps of hoses where abouts is it
Lumps of cheese
44
Warrnambool
The heater hose, on the right hand side of the motor. It's a 3/4" hose i think from memory. Doing that means you also get the extra coolant that will be in the heater too so that's why i do it that way.
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
ok yeah and do you take the bottom radiator hose off too
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
really want to find that drain plug in the block
Lumps of cheese
44
Warrnambool
Certainly do. Flush when the bulk of the coolant is drained. Put the garden hose on the heater hose and flush, then reverse the flush by putting the garden hose on the block where you took the heater hose off.
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
cheers mate
Lumps of cheese
44
Warrnambool
I think the block plug is on the passenger side if you want to go that way, down the bottom half way along. I only go the other way to get all the coolant out of the heater. It can be a real bitch to get the air out of the system too once you replace the coolant.
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
i have always just left the cap off and let it bubble
