aszaheer
Hi guys, my car overheated a few weeks ago and when I opened the radiator cap it was completely dry. A few problems I've been facing since are:
1. I have to keep topping up coolant in the radiator after a few days.
2. The radiator doesn't seem to be pulling any coolant from the recovery tank. It even overflows sometimes.
3. I can press and flex the radiator hose even after the engine has been running a while. It is not hard to the touch.
I haven't noticed any coolant leak anywhere and my car hasn't overheated since that once. I have bled the radiator but the symptoms still persist. I think the radiator cap needs to be changed which I will do before I flush the cooling system. Ok so now my questions:
1. Do you think the symptoms point to a faulty radiator cap?
2. Will the recovery tank be drained after I change the cap and drain and flush the cooling system? Or do any extra steps have to be taken to empty it?
I'm sorry if this has been answered before but I couldn't find much on draining the recovery tank after a couple days of research
