Coolant from engine :|
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by mking, Feb 18, 2008.
  1. mking
    mking New Member
    Newcastle
    Bagged vs caprice sII
    Replacing water pump (VS)
    Renamed thread found out what problem is now just need to know how hard it is to replace the dam thing haha if it seems to hard ile have to get a pro to do it. Would be harder then replacing a radiator?
  2. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    It could be your water pump leaking.
  3. mking
    mking New Member
    Newcastle
    yer ive pretty much narrowed iot down to that now so hopefully i can pick one up cheap n bang it in myself. Cheers
  4. vxcalais_01
    vxcalais_01 Active Member
    VX Calais 3.8
    Yeah, waterpump, do it a.s.a.p and dont forget the pellets if its an ecotec......
  5. mking
    mking New Member
    Newcastle
    What are pellets?
    How hard is it to put a water pump in by yourself?
  6. mking
    mking New Member
    Newcastle
  7. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Takes about 45 minutes to do a water pump. The pellets are used to stop minor leaks. I have never used them myself. Make sure the job is done properly and you shouldn't need them.
