leethal1
- Sep 7, 2010
- 145
- 0
- 0
- Location
- Perth Australia
- 2005 Adventra LX6, HG monaro
Hello All,
I have read as many posts as possiable before posting this one but i can not find that i'm after.
I seem to have a small coolant seep coming from the lower radiator intake, hope this makes sense - from the radiator water goes into rubber hose then into a steel pipe to the back drivers side of engine, I seem to have a leak where the steel goes into the block, are they easy to fix? is there normally any corrosion issues around that area? just dont want to pull it apart and find a major rebuild problem, the car has not lost any/much coolant from the overflow, only seems to seep.
also if anybody can help with aircons - I have lost most of a charge with UV die in the system. I am unable to see where it went. any ideas? have been looking with uv torch everywhere, pulled the fan out and can not see any dye anywhere.
thanks in advance.
Lee
thanks in advance.
Lee
