coolant leak
BR00T
40
QLD
Holden commodore vy s2
I drove out of the car park and got out to check mail, I noticed a patch of fluid under the car thought it was just the air con until closer inspection saw it had a small patch green fluid mixed with it. I took it back to the mechanic who had serviced it 2 weeks ago, got oil change and air filter etc. He looked at it over and could not see any visible signs of leaks. Car was not overheating, coolant levels were fine. Any ideas on what this may have been?
losh1971
North Tas
VE SS Ute Shed Ornament
If its coming from the AC drain then its most likely a leaking heater core.
BR00T
40
QLD
if it does turn out to be that, it's damn expensive to fix. don't use the heater so how much am i looking at for a bypass roughly?
