Skylarking
- Feb 3, 2018
- 10,081
- 10,497
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
Thats probably the case but this numbers would be kPa not psiI read somewhere on the forum that the original cap pressure was 120 psi. & was then upped to 140 psi.
120 kPa = 17.5 psi
140 kPa = 20 psi
120 psi = 700 kPa = 7 atm = 7 bar = 70 meters under water….
Never heard of any automotive cooling system at such pressures
To put that pressure into a non car perspective… a recreational open water scuba diveing certificate allows a diver to go down to 18m while recreational advanced open water scuba diveing certificate can go down to 40m. Diving beyond 40m requires specialist “technical” training and special gas mixes as air just won’t cut it if you want to avoid narcosis. Anything beyond 60m is classified as deep diving… 70m down is deep, really deep unless you are extremely well trained… but maybe not that deep…
In 2014, an Egyptian man dove to a depth of 1009 feet and 4 inches (307.6m), setting a new record in the Guinness World Record for the deepest ever-recorded dive. This dive took 12 minutes to get down, but 15 hours to ascend in order to properly decompress
