Coolant on the top left side of my engine
eagle13
40
Vx SS & VZ Crewman
I took my engine cover of my vs and found a drop of cooland the size of a
10c piece on the top left side of engine i know i need my valley cover and rocket cover gaskets done could this be the problem i did not think coolant went anywere near the top left side of engine
holden007
VRII
Subaru Liberty
Only one drop?
If one drop, wait till you see many drops. then you can diagnose the problem.
Harvs82
39
Glen Waverley VIC
MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
Anywhere near where the top radiator hose is connected to the thermostat outlet? If it is near there, chances are that the thermostat gasket is shot, and coolant is seeping out from there.
Vr acclaim
manifold gasket
i got the same problem n had a fella out 2 help n just looked at the coolant n where it was n said yea its ur manifold could be differnt for u but from wat i read it sounds the same
eagle13
40
Vx SS & VZ Crewman
I know my mainafold gasket need to be done i checked it today and no more coolant is there
Centurion
VR commodore V6 3.8lt Manual
Manifold gasket leaking, you will also find a little bit of oily grim on the inside of your radiator cap, and if you run your finger inside the resivour bottle you will feel it oily also.
