Coolant question
quombone
SunshineCoast
VT V6
Hi,
I have just purchased a VT, during a quick check of everything I noticed that there was only water in the cooling system. My question is, the water seems very clean, so I was thinking of just draining the radiator and adding Tectaloy V Plus straight in, to the correct level and it should mix through.
Would it be ok to do it this way?
cheers
quom
holdenvtman1123
Improvise Adapt Overcome
Broken Hill NSW
www.google.com.au
VZ Adventra LX6 2006 3.6L
Always use Holden coolant 50/50 with distilled water. csiro says its second best in the world and wont eat your gaskets. As juzo said flush out the radiator with the hose first at least. there is a drain plug on either side of the block for draining coolant out. change your thermostat to an early opener and dont forget to get the air out of the system when its full of Holden coolant.
quombone
SunshineCoast
VT V6
What does CSIRO rate No.1 ?
early opener thermo, completly nessesary?
Thanks for the info
Simonn
keilor down, vic
Vx S pack m5
its not hard to drain your coolant just undo the bottom radiator hose and take off the radiator cap. Once its all drained refill with clean water, Run car for untill thermostat opens then drain again through bottom radiator hose and then refill with proper coolant. If I were you though il run a coolant flush through it just for peace of mind.
BOGANV8
I gotta V8 whoot whoot
41
Armidale
VX 02 SS LS1
It prob would mix through evently but you dont know whats inside the block let alone the bottom of the radiator. So its best to flush it completely only take and extra 10-15 min..
Dont bother with the Holden coolant it only regular coolant in a Holden bottle and it doesnt do anything more than what you would buy from repco or supercheap.
Been filling 1000s of commodores including my own SS with repco coolant from work for years and never seen a head gasket go or rust the heads out or stuff water pumps...
greenacc
Searching for the billion
VE Berlina
BOGAN , do you need the tablets with Repco coolant ?
BOGANV8
41
Armidale
VX 02 SS LS1
I have never put them in either and never had a prob with the many v6s and v8s done at work or the ones that i have owned..
My personal opinion is that they are a bit of a con by Holden...
wrx884
WA's ASR Rep
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
Im draining my coolent as we speak in prepare 4 the heater core change but atm i cant seem 2 find the 2 knock sensors on the block??? ive got the VT cd manual but the pic that shows u the cover plate and sensor is very small n hard 2 tell where it is exactly ne1 able 2 explain where bouts???
Also ive been using the repco coolent and will b again 4 the VT all mechanics ive spoken 2 said 2 use either tectaloy or the repco stuff.
