Coolant question
Tom_1569
Ecotech Power
Gippsland - VIC
'14 SR5 Pusslux
Im draining my coolent as we speak in prepare 4 the heater core change but atm i cant seem 2 find the 2 knock sensors on the block??? ive got the VT cd manual but the pic that shows u the cover plate and sensor is very small n hard 2 tell where it is exactly ne1 able 2 explain where bouts???
Also ive been using the repco coolent and will b again 4 the VT all mechanics ive spoken 2 said 2 use either tectaloy or the repco stuff.
In the manual it does say to remove the Knock sensors to drain the cooling system, I was abit confused. Spoke to the local holden mechanic, he said its a joke, you cant do it with out a hoist, and even then you'd be struggling to pull them out with out alot of effort, and its only bout 100mls you drain out he said.
I didnt bother when I replaced nearly all our cooling system. Personelly I use Holden coolant and the tablets because I know my mums partner will find any excuse to say Im not looking after the car :p
wrx884
WA's ASR Rep
37
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
Ahhh thats good so wen flushing the system the sensors wont get damaged??? thats mainly wat im worried about if i dont have 2 remove them i wont :thumbsup:
BOGANV8
I gotta V8 whoot whoot
41
Armidale
VX 02 SS LS1
^^^^^ I would safely say when holden techs do a flush they wouldnt remove the knock sensors either.....
NOW GET THAT HEATER CORE CHANGED OVER.:yeah::yeah::yeah::yeah:
holdenvtman1123
Improvise Adapt Overcome
Broken Hill NSW
www.google.com.au
VZ Adventra LX6 2006 3.6L
tabs are to protect ur water pump
Simonn
keilor down, vic
Vx S pack m5
iv heard that the tablets are to protect the water pump inpeller from buildup? which I think is crap and iv also heard that the tablets are to lubricate the water pump seal which sounds more true. But still think it is a pull
BOGANV8
41
Armidale
VX 02 SS LS1
Holden tablets are a BIG CON!!!!!!
holdenvtman1123
Broken Hill NSW
www.google.com.au
con or not i felt safer using them when i had a VP v6. i don't need them apparently with the VT v8 5.0.
