Coolant smell
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Jarrad/vr, May 18, 2020 at 8:46 PM.
  1. Jarrad/vr
    Jarrad/vr New Member
    Wallan
    Vr berlina
    Hi all I have a 1994 vr berlina and when it’s warmed up there is a coolant smell while driving. Could it be because it’s an old car? Temperature is fine too doesn’t get hot or anything like that
  2. losh1971
    losh1971 Well-Known Member
    North Tas
    VR Ute V6
    If it's inside the cab it will be 100% the heater core leaking. Pretty common issue.
  3. Jarrad/vr
    Wallan
    Vr berlina
    Ahh okay that’s probably why it makes a gurgling noise while driving.
    They easy to replace?
  4. losh1971
    North Tas
    VR Ute V6
    Depends on what you call easy? Can it be done at home absolutely yes, just not the regas. Is it a big job yep to do it right, it sure is. Cost me around $400 in parts and about $1000 in labour plus an A/C regas. Do it right and you will love the freezing cold A/C and super hot heater. Do it half arsed and you will have a fairly warm heater but that's about it. Bodgy way is to slash the heater pipes and join them with heater hose and four clamps. I chose the hard way and have no regrets as my A/C evap was blocked and was stopping the A/C from working properly, it was barely cold in summer. Unfortunately no way of cleaning the evap without pulling the dash out.
  5. Jarrad/vr
    Wallan
    Vr berlina
    Damn okay, I woudnt have a clue how to, how much do you reckon my local mechanic would charge? Probably would be easier since I have no one to do it
  6. losh1971
    North Tas
    VR Ute V6
    Labour will be around $1000, regas $130, parts if he cuts you a deal like my bloke did with me $400. If he charges retail parts will be around $600.
  7. Jarrad/vr
    Wallan
    Vr berlina
    **** okay, what about if I supply the parts? And just get the labour done? What parts will I need besides a new heater core?
  8. losh1971
    North Tas
    VR Ute V6
    Bodgy way is still around 3hrs work plus a core. My core was $145 IIRC.
  9. Jarrad/vr
    Wallan
    Vr berlina
    So would it be better if I supply the heater core and just pay the labour for them to install it? Because my grandfather is well known to the auto place that I go to so maybe it might be the best option?
  10. losh1971
    North Tas
    VR Ute V6
    Evap and TX valve. You could take a chance on the evap but for $150 if he looks after you it's money well spent considering you will be looking at close to $1200 labour including regas.
  11. losh1971
    North Tas
    VR Ute V6
    Only you can answer that one my friend. It will depend if he insists on supplying parts.
  12. Jarrad/vr
    Wallan
    Vr berlina
    Okay cheers for your help mate, I’ll probably just buy the parts I need and take it to them, that’s what I do usually
    losh1971 likes this.
