  1. Holden V8 SS Ute
    Holden V8 SS Ute New Member
    V8 VN Track Car
    How much coolant do commo VS's hold?
  2. dufus
    dufus Donating Member
    rickshaw
    VR's hold 12 Litres so im guessing a VS should be similar.
    EDIT: just looked it up and it is 12 Litres
  3. Harvs82
    Harvs82 Active Member
    Glen Waverley VIC
    MY08 Subaru Liberty GT-B & MY16 VF II SS Redline
    V6 engine cooling system holds 12 litres, 6 litres of water, 6 litres of coolant concentrate, not the premixed crap. 'Cooling system' means the whole thing, radiator, block, hoses, reserve tank and heater core inside the car. Even when draining and flushing the block, you can't get the whole lot out, as 3 litres sits above the heads, so you need to take that into consideration when changing the coolant over. You can however flush out those 3 litres so that they are replaced with clean water by removing the thermostat and flushing from the top of the block.
