As far as i'm aware the primary reason for the factory running such high engine temps is for pollution reasons. I think it has been well proven that for economy you run engines at a higher temp. For power you run the engine at a slightly cooler temp. Having said that, I've noticed no reduction in economy from running the engine with the cooler 82 degree thermostat
If you care to look, download Tunerpro and have a look at the tunes for these engines. You'll see that 82 degrees is within what is considered to be the normal operating range, check the fuel Vs temp correction tables. maybe someone can remind me at which temp the PCM starts add extra fuel to help keep the combustion temps down to stop pinging..... (If extra fuel is being injected it means that you not producing as much power
Engine oil tends to get contaminated easily if the oil isn't bought up to it's proper operating temp. This would be a problem if you do a lot of short trips. If this is the case, make sure you take the vehicle on a decent drive every couple of weeks to ensure the engine oil gets up to the proper operating temp.
I've run a oil temp gauge for a fair few years now and from what I have seen, it takes the oil a lot longer to heat up then it does for the engine coolant. Just jumping on the motorway isn't the best way to heat up the oil as the engine is under a relatively light load (so producing relatively little heat) and you have a lot of airflow through the engine bay which is actually cooling the engine block/sump (the alloy sump on the ecotec conducts heat very well).
On the subject of heat. It is a lot easier to heat something up then it is to cool it down. Although the cooling system may be pulling the coolant temps down relatively quickly, that is only the coolant that is flowing through the engine, heat soak through the rest of the engine takes a lot longer to dissipate so in my opinion of you can prevent that extra heat soak then it's a good thing.
