RX25SE
Real cars are steel cars.
- Jan 20, 2009
- 1,260
- 10
- 38
- Location
- Melbourne
- MY07 Liberty 30R Spec B 6sp wagon
Before you buy a new radiator, I would do the following in addition to the above suggestions.
Get a mechanic to connect a scan tool and read the engine temp from that. This will take the reading from the coolant temp sensor (for the PCM) rather than the sensor for the gauge. You may just have a faulty gauge.
Run the engine from cold and feel the top hose. When the the thermostat opens, it should get hot very quickly. With the scan tool connected, it will give you an idea if the thermostat is opening at roughly the correct temp.
This is a bit rough, but it sort of works. With the top and bottom hoses disconnected, block the bottom hose outlet with your hand and have someone fill the radiator. Quickly remove your hand and note the rate at which the radiator drains. This may tell you if the radiator is blocked.
