hako
Donating Member
- Aug 1, 2004
- 8,020
- 96
- 48
- Age
- 80
- Location
- Toowoomba SE QLD
- VS11 BT1 V6
It's a V6
I'm liking the checking the leads, last night the tacho bounced so I'll do the leads first and let you know
I just don't really understand why it would be normal for any car to be up around 3/4 having never been there before but I feel like I'm watching the gauge more than the road because I don't want to miss if it were going to flip into the hot and I miss it!!
Will do the leads 1st!! Haven't had the heater on except to bleed it, but have only had the car since last Sept so have never used the heater in it! So help a girl out here and go further with why the rushing water sound please????
The VS Commodore ECOTEC enhancement. This means Emissions Control Optimisation TEChnology....part of this system includes running the engine at higher temperatures to burn the fuel more efficiently and reduce emissions...that's why the cooling system runs at 1.35Kpa or 20 psi which is very high and this prevents the coolant from boiling till approximately 135deg.
The rushing sound is caused by your heater tap not turning off - this means coolant flows thru the heater all the time....when you turn the selector dial to COLD, the coolant tap should turn off....yours apparently doesn't. There are a few reasons why it is not turning off so ask if you want more info. This should not make the car overheat - if anything it will keep the car cooler as the heater being on will cool the coolant. The gauge running 1/2 to 3/4 is just the gauge reading - different cars have different gauges that behave differently. If the gauge flips into the red, a warning chime "should" sound...that's if the electrics are OK...are you losing coolant?...this is important.
