Cooling System (Pellets)
skotlar
41
VU S2
Hi All,
I'm new here and new to owning a VU series 2, 3.8 ute in the last week.
Given that it hasn't been serviced in a while I flushed the cooling system today and had bought the pellets to go in also, but forgot to add them.
Is it safe enough to crush them and just add them from the radiator lid rather than the hose seeing as i've now filled the system?
Scott
fitz_vt
Pass Me A Wrench.....
Adelaide - South Side
VT Commodore SII Olympic Edition
yep you can as long as you crush them alot before you put them in , pressurize the system (as you would if you were bleeding the system then let it cool and make sure the pellets have circulated also make sure its a 50/50 coolant mix thats very important otherwise it will overheat and cause all sorts of problems... (pre mixed is only 33% UNLESS specified)
skotlar
41
VU S2
Thanks heaps guys, I used the genuine Holden coolant 50/50 so that's all good, I was just kicking myself that I paid for the pellets and forgot to put them in after all that.
Appreciate the replies.
MR_VX
Forced to be Fast
Townsville, Qld
VX S pac SII Raptorcharged
])[email protected]()N;1763625 said:
Do you really need them anyway ?? what do they do?
You dont have to but, is reccomended you should use them, it stops corrosion happening in the radiator, its cheaper to buy the pellets then a new radiator.
I normaly just put them in under the radiator cap :confused: ive never had a problem before, crushing them up makes more sense tho.
VT
I just put a new radiator in yesterday. I've only put coolant in it.
One of tanks on the old one slit luckily I wasn't to far from home.
skotlar
41
VU S2
I thought that also, but it states it in the book and for the $7 from memory, I didn't complain.
On another note, I noticed there is coolant that has run under the surge tank since flushing, would this be as a result of filling too much coolant?
VYMAD
SILVERFOX
46
BUNDABERG Q
VY EXECUTIVE S2
Not many people worry about adding the pellets. I have never used them.
