Corey Smith
Corey Smith
27
Vz commodore wagon
Hey guys new here just wondering how to fix air con in my vz it won’t change the settings just stays on window
Fu Manchu
WA.
Will be a vacuum actuator.
Immortality
Staff member
Sth Auck, NZ
Immortality
Staff member
Sth Auck, NZ
Trevor loves holden.
vs commodore
So he could look at what has already been said on the matter, but I gave him the link again just incase he cant find it.
Immortality
Staff member
Sth Auck, NZ
Except the thread you linked was from someone else so your comment did not make sense....
Fu Manchu
WA.
Holden suggests that if the air is stuck on windscreen then there is likely to be a vacuum leak.
A vacuum gauge is used to test this.
Leaks can occur in a lot of places in the HVAC. Most of the actuators can only be accessed by removing the HVAC from the car which means degassing the AC, removing the enitre dash assembly including steering column and then, finally, the HVAC unit.
