correct fitting of slotted brake disks
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jas98, Sep 28, 2008.
  1. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    alright now some of yous may know i got slotted brake disks etc.....i installed them a while ago like how they came off the car.....but now i have been reading a few car mags etc and i see they are installed differently then the direction mine are.....so my question is which was is the correct way? any pics would be good
    thanks
  2. WAGON MAN
    WAGON MAN Gas Sleeper
    North Coast , NSW
    VX S2 Berlina Wagon with Phreddied bits.
  3. WAGON MAN
    North Coast , NSW
    Pic courtesy of Low VP
  4. VSIIBerlinaL67
    VSIIBerlinaL67 New Member
    VX SS M6
    did they make your braking performance any better or just for looks?
  5. jas98
    jas98 Active Member
    maryborough QLD
    cheers for that "WAGON MAN" ...looks like there on teh right way after all :D
    as for braking id have to say it does help i did have bendix ultimate pads on there (front and back) but **** me they were dusty as ...after one day the wheels were black!! the pads i have on there now are the normal bendix which i got with the rotors (rotors and pads came of a car at wreckers....both near new;)) and after 3 weeks the wheels were still clean. I do have to admit though that the ultimate pads pulled car up allot better but when you are highway driving the slotted rotors help allot especially with quick stops from 100.
    I got them mainly cause they were cheap and i was looking into replacing my front rotors and i saw these ones at wreckers that i got for like 176 for all 4 basically brand new
  6. ephect
    ephect Donating Member
    VS Acclaim V6
    remember is not always the case. if they are branded, they generally come with a sheet to say which way/side they go.
    some slots are made outward venting, and some inward venting, which way you have them wont matter if the internal vains are straight!
    if the internal vaines are curved, they need to be installed the correctly regardless of the slots direction. i'll find you a pic of what i mean..
    Edit: check this post.. http://www.digitalcorvettes.com/forums/showpost.php?p=968113&postcount=14
  7. LowVp
    LowVp VP Enthusiast
    Dalby, Qld
    VP Ute 3.8T T56
    it will make a difference as the pad is wiped by the rotor any crap is assisted by the spinning of the rotor to help pull it outwards, inward venting to me is like ****ing into the wind. but the DBA rotors will have a R and L on the part number
  8. ephect
    VS Acclaim V6
    i agree, most brand names are done properly, but some no name rotors arent.
    but if the internal veins arent facing the right way and venting the heat out of the rotor, its not cooling properly and hello warpage
    most are curved veins and need to be correctly installed, if there straight veins, set the slots to vent outward.
  9. shanhsv
    shanhsv Luvo
    Muswellbrook, NSW
    VSII Calais V6 & VSII Senator 215i
    I had front set put on about a year ago,it came with L & R stickers to tell me which one went where.The slots seem to go with the direction of the rim rather than against,i'll put up a pic tomorrow if i can to show you what i meant
  10. jas98
    jas98 Active Member
    maryborough QLD
    mine didn't have L or R stamped on them but they are on the right way as i compared them to the DBA site (there DBA rotors)
  11. shanhsv
    shanhsv Luvo
    Muswellbrook, NSW
    actually the big pic above is exactly how mine is set up,providing the brake caliper is more towards the front of the car
  12. LowVp
    LowVp VP Enthusiast
    Dalby, Qld
    VP Ute 3.8T T56
    the above pic is my front right
