Correct oil
WildKat
My 2013 VF SSV
Can I use 15W-40 in my L77 engine???
Thanks Kat
07GTS
Australia
VEGTS BUILT BLOWN E85
would be ok but id lean more toward a 10-40 the bit thinner for cold is better for it
vr304
Auckland, New Zealand
2007 ssv manual
Don’t cheap out on oil! The factory recommended oil is 5w30 as long as you get a full synthetic close to that u should be fine
tml678
2017 HSV30 Senator, 2002 Corolla..
Thanks Kat
You can use whatever oil you like..but unless you're getting up there in kms (ie north of 200-250 thousand) and the engine is getting a bit tired and rattly, then a 15w is a bit heavy in my opinion. As someone else said, a 10w is a better option IMO.
