Sounds like a recipe for disaster... Wheel nuts that don't pull the wheel to the centre of the hub, there's no central locator AND they take all of the load? Sure they'll bolt up, but not safely by any stretch of the imagination.I was told by BCI wheels where they make them, that everything has clearance, and if you use "wobble nuts" you can run Chevy 120.65 wheels if tightened slowly in the correct sequence. he also said the center bore has clearance, so the studs do all the work.
So if they don't centre on the hub or on the wheel nuts/studs, what do they centre on?Chevy 5x120.65 vs Holden 5x120 that's only .65 of a mm... His point was there would be that much clearance on a Holden wheel at the center hub anyway, if there was not any clearance you would never get any wheel on or off. I realize wheels are high-speed dangerous things, but there is a beautiful set of corvette wheels I an temped to buy. they do make and sell "wobble nuts" just for that reason...just sayin.
