Cost of Lowering
DUK13Y
When in doubt, slide it out
Sydney, Australia
www.facebook.com
VEII SSV, VYII Berlina, '97 Lancer
I know this has been covered here and there but what would be the ball park price to lower a VYII to SL (fronts) and SSL (rears) with kingsprings? I am under the assumption that shorter shocks and a 4 point camber kit will be needed as well as fitting. How often will I have to get a camber kit? What are the recurring costs involved?
Thanks in advance
nicko
Carbon Positive - DO IT!!
sa
75 cruiser ute
$300 to have the springs installed. dont NEED the shorter shocks. Camber kit around $300-$400 installed. Camber kit is simply bushes and they DO wear over time. Maybe in 150,000kms time it could need doing. Seriously just call a few shops and get a proper quote.
DUK13Y
Sydney, Australia
www.facebook.com
Ok thanks mate. I thought with SSL's you needed the shortened shocks. I might look into doing it a bit further down the track. Get the money rolling in a bit first :yeah:
DUK13Y
Sydney, Australia
www.facebook.com
Oh ok. I didn't know they were that cheap.
How low are your springs?
Did you need shorter shocks?
Did you need a camber kit?
pepstar87
Central Coast, NSW
08 SSV M6
I run SSLs in rear and SLs in front and I dont run a camber kit or shorter shocks.
Its fine mate..I plan to put SSSLs and SSLs in and see how she goes! :)
TMM
OEM+
VIC
VY Berlina S2
If you want it to handle rather then just look good you're best off fitting new shocks (especially if they haven't been replaced before). I think you will need a camber kit if you're coming form FE1. Borderline if you already have FE2.
gslrallysport
VZ AWD One Tonner
DUK13Y
Sydney, Australia
www.facebook.com
Thanks for the info guys. I think I might get the camber kit as it's only $100 but can I fit the camber kit myself or do I need someone else to do it?
