cost of motor.
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Bz Kn33z, Mar 4, 2007.
  1. Bz Kn33z
    Bz Kn33z Active Member
    Mildura
    Black VN V6 Turbo
    Hey i was just onedering how much would a second hand vn to vr engine would cost around the 500 mark and what things could i do to the motor when its out of the car to get it up and running good i was planning on doing seals and gaskets ect.
  2. cruzncommo
    cruzncommo Banned
    QLD
    VP 5spd
    300-700 bucks and get it rebuilt.
  3. Bz Kn33z
    Mildura
    Black VN V6 Turbo
    how much would a rebuild cost? cause i am going to do it with mates so dont really want to send it to a machanic and loose alot of money
  4. cruzncommo
    cruzncommo Banned
    QLD
    VP 5spd
    bout 1 grand for the kit if you want to DIY and 2-5 grand for a mechanic to do it.
  5. PaRaDoX
    PaRaDoX Because Racecouch...
    Melbourne, Victoria
    none
    ..... 1 grand???
    i mean sure if you can acid bath it, crack test, it balance it, hone it match the pistons & rings, shave the heads yourself... and rebalance the crank...
    ACL rebuild kits are $780~ that includes pistons, rings, bearings, etc
    my local wreckers has complete engines on special for $80... (complete) normally $120... its self serve tho... look round, they're not too expensive
    id recomend doing headgaskets, top end seals change the oil, engine mounts, oil filter and rear main seal (those pissy annoying things)
    a rebuild will cost you $2500-3500 for a standard rebuild including parts and labour... they'res alot to building a engine and your still going to need a shop to do some of the work (machining)
    in my opinion, go find a stocker, buy it and put it in... and pick up a ACL VRS kit and change rear main + engine moutns and your set.. the engines are tough... stick with the same model engine you have.. it makes life easier
  6. Bz Kn33z
    Mildura
    Black VN V6 Turbo
    From the wreckers i can get a motor S1VN for $500, thats pulled out pressure tested and all that stuff not complete motor though.
    I was wondering what a good compretion for a V6, The guy said around 150 160 is good so yeah.
    Thanx to all the people who have wrote back and answered my Questions.
  7. Burt_vn
    Burt_vn Back in the game
    Gold Coast
    VG V8 5spd, 400hp 5spd soarer, vq stato
    yeah that compression is about right 160ish would be your benchmark, as for a motor for $500, try a few other wreckers. I got quoted a couple of hundred for a complete s1 VN motor when i blew my old one up lol. Ended up getting one of my dads mate for $100 though.
  8. Bz Kn33z
    Mildura
    Black VN V6 Turbo
    I am in Mildura top of VIC, so there is only like 2 wreckers cheapest i found was $550 so thats ****** but oh well he said this motor has about 155 156 compretion. but i am going to pull it all down before i put it in my car.
  9. Bz Kn33z
    Mildura
    Black VN V6 Turbo
    Picked the motor up today looks shabby. But it will come up ok. The wreckers want my old motor though. I dont really want to get rid of it to them but i guess i will. I will just strip it cause where is new parts on there make the best of the 2 motors and make a good 1 and chuck it in.
  10. samuels
    samuels Active Member
    VX HSV XU6
    WHAT...no way...did he have a sign up stating this? he can really only ask for your motor if he is selling a reconditioned one.....i don't know how your wreckers work over there, or what the laws are,but i have never heard of this situation down here in tassie
  11. Bz Kn33z
    Mildura
    Black VN V6 Turbo
    Yeah Well i paid for the new motor, its not reco and it does'nt have all the bits and peices, but i didnt have to sign anything cause i was going to sell stuff of my old motor like rocker covers and whatever else.
  12. timmy_tam
    timmy_tam New Member
    VN calais 91
    i've got a motor up for sale if u want to use that to trade with :D
  13. samuels
    VX HSV XU6
    you can get an exchange VN series 1 motor for $3440 and from memory thats a long motor,if you know a qualified mechanic,a carton of smokes or beer and a couple of hundred dollars,he may charge less,or if your that way inclined put it in yourself...the motor and get your mechanic friend to sign it....for warranty purposes :)
