could this be the throttle position sensor on its way out.
to_easy
newcastle
vr commodore
car only revs to 3 - 3 half grand then it wants to die, could this be the throttle position sensor on its way out, i did the wire test and got (code 12) all good so it says but i have noticed that the car rev fine some times after i turn it off and start it again and then it starts to muck up again when i rev it.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
If it's a VL, check the fuel pump.
Brett_jjj
Tamworth NSW
vs commodore
Check for a blocked fuel filter, blocked air filter, or blocked exhaust (blocked catalytic converter).
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Did you just change your ride? I swear it said VL when I read it the first time.
But same, check fuel pump. And as Brett said.
