Powerbait
- Jan 13, 2011
- 7
- 0
- 0
- Age
- 45
- Location
- murrumbateman
- VH STROKER
drums are probably oversize and/or badly scored.
drum brakes are a bit fiddly, but not difficult. Make sure you back the handbrake cable right off first. Just pull one side apart at a time so you can check the other side if you forget where everything goes.
steering rack swap isn't difficult, but you'll really need to get the toe adjustment done after you have done the swap. Have to be fairly lucky to get it right by eye.
power steer pump - just remove it & take it to a steering place and get them to put a kit through it.
auto pan gasket, easy. But make sure the transmission is cool before you do it. The oil is thicker and won't burn you when it runs down your arms
Listen to this post , its spot on.
