cracked air conditiober pipe connected to front radiator
jdcasagrande
2003 VY s pac supercharged
Hi guys,
I replaced my radiator because it was leaking coolant, when connecting the new radiator i bent the long air conditioner pipe on the passenger side which runs to the firewalk, all the gas sprayed out, firstly is this gas lethal? And secondly are tge pipes easily replaced? Its just and aluminum pipe.
Any help is appreciated.
Stretchomatic
35
Ardlethan, NSW
www.facebook.com
86 VL Berlina M5
Gas shouldnt be lethal. Dont directly breath it or anything. I get a bit of spray when purging lines at work.
Pipe should be available as a spare part. Gas will cost a bit though.
Cheers, Stretch.
K-BAGZ
De Plane! De Plane!
Far North QLD
VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
R134a is highly lethal. Can cause death and blindness.
Only certified personnel are to repair/replace/recharge AC systems.
turmoil117
Donating Member
33
Armadale
Vs berlina
I can tell you right now that you are wrong, its not very toxic at all
K-BAGZ
De Plane! De Plane!
Far North QLD
I'm not even going to argue with your statement. R134a is a non toxic gas, but it is still highly lethal to the human body if handled incorrectly.
Pollushon
Boost gives me a bar....
VY SS
Spot on, non flammable and non toxic. The danger is oxygen deprivation in enclosed spaces (heavier than air and settles low), but that's some serious Darwin Award territory.
OP you may have just bent the pipe so it pulled loose on the condenser. Wreckers should have them or you may find it's salvageable. Hopefully the condenser is okay. I did have a working one I pulled of my beast fitting the blower but alas I chucked it.
turmoil117
Donating Member
33
Armadale
Vs berlina
Yep that's exactly it, its as deadly as any aerosol like air freshener or deoderant
Sabbath'
Redblock Jesus
80 Series// VFII Black Edition
Seem to remember something about how cold the gas is aswell. And what it could do to certain body parts if contact was made.
turmoil117
Donating Member
33
Armadale
Vs berlina
Yep just like if you held an aerosol can right up against your skin and sprayed it.... just a bit worse
Mrmotox023
Mildura
03 vy s pack & vl
i just replaced that pipe on my vy its the high pressure line, it was $40 from holden dealer and u can fit it your self without removing the radiator, just gota b very careful not 2 bend it 2 much and just take your time
