- Feb 22, 2005
- 1,188
- 335
- 83
- Age
- 36
- Location
- Geelong
- '97 Caprice 355ci & VZ SS Ute
first off, welding a wheel will make the vehicle un-roadworthy.
ive had a genuine set of senator signatures since they pretty much came out. they had done roughly 20 thousand K's.
i wanted to make use of them again, but the rears had bad camper wear so i took them to get flipped.
one of the employee rolled a wheel back out and it had the slightest crack on the inner lip. it just ran past the bead but it never lost pressure.
so i took the rims home and started looking for a single rim. only place i could find one was wheel king for $450.
i called up my local holden spare parts and got talking to one of the employees. he told me hes had two sets of rims where one wheel has been cracked and he got them repaired.
he told me hes never had a drama from re-crackin, losing pressure, or buckled from welding.
so i took his word and went down to engineering place that did his wheels. the owner looked at it and told me he could fix it.
he said hes done a few wheels and never had anyone come back from re-cracking.
after 3 days he told me to come pick it up.
(welders can correct me here) he drilled the end of the crack, V'd it, then welded the area.
i took it down to tyre shop and got them to throw some new tyres on it (to try and pro-long the life of the rim) and balance it and go over it and see what the thought.
they were happy with the job he did and it balanced good.
i havent fitted the rim as of yet, im gunna give it a week or two and moniter the pressure and see if it leaks.
ive made this thread as only a rough guide. each rim, weld, road traveled on is different. but ill be updating this thread if anything happens. but this will give people a better idea if they cant afford a new rim that their is a cheaper alternative that can get them by.
the weld it self cost me $99 and the mob that did it are located in Geelong
Robert Lange Engineering
5223 1944
Welcome - Robert Lange Engineering
for the melbourne guys i did give this guy a call. he wasnt confident in the life of the rim after its being a welded but said he could do it for $150
Wheel Fix It
0418 34 34 82
Wheel Fix It Mobile Alloy Wheel Refubishing
5223 1944
Wheel Fix It
0418 34 34 82
