Cracked where the oil pressure sender goes
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Fletch_QLD, Dec 13, 2007.
  1. Fletch_QLD
    Fletch_QLD Member
    Brisbane Bayside
    VU II SS
    As the title says - there is a crack in the alloy piece where the oil pressure sender unit, and the oil filter screw in - accompanied by a hefty oil leak.
    Can anyone tell me how big a job it is to replace this part ? Can the part be sourced at repco etc or do I need genuine holden ? What is the part called ?
    Any help appreciated!
  2. dufus
    dufus Donating Member
    rickshaw
    The oil filter adapter isnt to hard to replace if you have a good workshop manual and follow the instruction precisely when removing and reinstalling the oil filter adapter. I'm not sure whether Repco have them in stock but im sure that they could order them in if you asked them to.
    Fletch_QLD likes this.
  3. Fletch_QLD
    Fletch_QLD Member
    Brisbane Bayside
    VU II SS
    Thanks for the reassurance. Now that I know what to call it, I rang holden - only $27 inc gasket, so that's done, as for fitting - no manual here, so can anyone provide any pointers ?
  4. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Give this a go.
    You don't have to do step 7.
  5. GTP 85
    GTP 85 291 hp @ the wheels
    Murray Bridge S.A
    MY04 WRX, VS SSenator & VS V6 track weapon
    Its pretty straight forward mate.. look for all the bolts that go thru it, and undo them! i think i recall one of them was a real ar5e to undo, but you will soon learn which one lol.
    Give it a go, dont forget to put the gasket in there and maybe use a dab of gasket sealer too
  6. Fletch_QLD
    Fletch_QLD Member
    Brisbane Bayside
    VU II SS
    I have found the tricky one its too bloody tricky for me can not get a socket or spanner around it. It's the top left/rear 13mm bolt. Any tips on how to get this bugger out?
  7. Fletch_QLD
    Fletch_QLD Member
    Brisbane Bayside
    VU II SS
    Thanks to all for help and support - job done - all good :)
    Thanks to bill_randomhero for telling me what to call the part, thanks to Not_An_Abba_Fan for the picture and thanks to REV-231 for the warning - lol - it was a basturd that last bolt!
