boona15 said:
ok, ive got a dynotec 286, eys it is big, i run a 2500 stall, 860cfm ported banana intake manifold
, 75mm t/b, havent had any problems with foulings plugs as such, but get the low rpm misfire occaisionally, big top end difference with this cam s the duration is a bit extreme but i now have to rip the engine out cos the guys at road traffic now know i have all this stuff and arent liking me at all.....
lou, would the STARR intake manifold and 90 mm t/b setup be good enough to run the cam properly with 9.0:1 compression ratio as i have??
boona15, you state that you don't have a problem with fouling plugs, yet you do have occasional misfires, these misfires are due to plug fouling and are
then cleaning then selves up wen engine is taken into higher RPM range.
For starters the 9.0:1 compression is abit low for this camshaft as your dynamic comp ratio will decrease due to high overlap.
Boona the most successful intake manifold combo i have seen for this size cam
is a red line single plane manifold with a 4 barrel throttle body, this will change
engine characteristics quite a bit for the better.
If you were to go for a Starr manifold with a 90mm throttle body, you will kill
what little throttle response you may have had in the low RPM range, due to
the slowing of you intake velocities.
To make this setup work even better I would ever go as far as placing 4 60lb
injectors above the throttle plates instead of having 8 30lb injectors in the
manifold runners, if you chose to do this you will find that the engine will idle heaps better and produce **** loads more bottom end torque, due to the change from a closed plenum to an open plenum.
Prior to considering these options please disregard what some mechanics and
mates have told you in the past, and have a good logical think about what i am trying to tell you here.
The other thing I may mention to you is that, if you have noticed at the drags, there are more carburetter cars doing better times than fuel injected
cars, and that's with ignition system being a dizzy that has limited spark control and only have a dozen fuel circuit in the carb controlling fuel.
With the setup I have mentioned in regards to open plenum fuel injection, you have excellent control of both fuel and spark so there for you will be a winner.
Cheers Lou
BCT
