If all you want to do is find TDC you just need a degree wheel and a stopper in the number one spark plug hole/ You hand turn the engine over one way untill it hits the stopper
yeah i offered that idea to the dyno guy but he pointed out that on the black's the spark plug angle is only a few degrees higher than flat on the piston so getting an accurate TDC is next to impossible. because when the piston raises the stopper is pressed at 10 degrees, rather than the 45 or so it would need to be accurate.
then following on from that, the 1 and 2 lifters would need to come out to get accurate lift readings due to the .004 or so lash in anti-pumps. (i.e. i couldnt put my dial indicator on the end of the pushrod)
i have an old solid around here somewhere i can put in for the test but it still means taking the inlet manifold off AGAIN! (had to redo it after the build cos' spermatex gaskets have a sticky side and apparently they like to stick to the block but not the gasket. there is something to be said for cheap gaskets and a bucket of RTV high temp silicone)
and i dont mean to be a pain, but i am very aware of the fact that advancing and retarding the cam generally only moves your power band around and has very little horsepower benefit, however if i am currently running retarded (which seems to be the case according to the ellery's manual) then advancing the cam will give me a definate boost.
remarks on the cam card; INTAKE LOBE LIFT AT TDC = .081 which would mean that if i am retarded (which a lot of you are probably thinking right now) then lobe lift @ tdc would probably be 0.000, by advancing (or even zero'ing) i would be allowing that little extra air/fuel in and bumping up piston psi (willing to be corrected)
gah, i dunno. i do appreciate everyones input. i think the best option is probably stick in the new chain@ 0 degrees, if it is currently retarded then i will see a boost, and then if i want more advance, bump it up later. i just dont really want to be doing the same tasks over and over again, i.e. removing and replacing timing cover, inlet manifold, possible sump if the front seal gets naffed etc etc etc.
and coolant really isnt cheap.
*edit: sorry, i have a factory gearset fitted at the moment. when the build was coming to completion, all the little bits and pieces i needed and forgot about stripped me and i couldnt stretch the $150 for a new gearset. instead just replaced the chain for 30 bucks. yeah, i now know the importance of dialling in the cam while the engine is out of the car and your heads are off :S
