PeterC
My son has been working on his LY7 and got to the point of replacing the heads on the block after swapping camshafts. He placed the heads on the motor and torqued them down without moving the crank into the correct timing position. Now wen the motor is rotated it stops at two points with a hard metallic noise is if it hits a pin or something, prior to the heads being put on motor spun freely. We took the camshafts off still same problem, we tapped tops of valves and none seem stuck down (all springs extended, look same height by eye). We took sump of looked at crankshaft looks ok. However I suspect that WD40 usage on the big ends may have siezed one of the shells so it rotates and then stops, is this possible? Or is it possible a valve bent if a piston was at TDC when heads torqued?
