ok sorry my terminology used in performance vehicles is poor i have had a few beers.
so here the spec list that come with the motor
1 X FULLY RECONDITIONED LONG ENGINE .
REBORED AND HONED TO PERFORMANCE TOLERANCES.
CRANK GROUND AND LINISHED.BLOCK HOT TANKED,DECKED ,NEW WELSH PLUGS, BLUEPRINTED
HEADS FULLY RECONDITIONED ,NEW VALVES ,BRONZE GUIDES,3 ANGLE VALVE GRIND, BACK CUT VALVES,BOWL PORTED AND FLOWED.
SUPPY AND FIT NEW CAM BEARINGS.
1 X SET ACL PERFORMANCE PISTONS AND RINGS.9.5 :1 COMP
1 X SET ACL MAIN AND CONROD BEARINGS.
1 x Clive Roller 228 @50 Hydraulic Cam 3200 to 6700 rpm.
1 X SET OF PERFORMANCE VALVE SPRINGS AND RETAINERS .
2x Performance 70 mm throttle body c/o.
1x Performance chip to suit cam listed c/o.
1x Rollmaster Red timing chain and gears SINGLE ROW
2 x Hydraulic lifters( NEW ! NOT RECO)
1 x FULL GASKET SET
1 X SET YELLA TERRA ROLLERS STD RATIO.
1 X 3500 STALL CONVERTER TO SUIT T700.
1 X TWIN THROTTLE BODY MANIFOLD AS SHOWN.
6 x GROUP A INJECTORS CHEMICALLY CLEANED ETC
and sorry for me poor spelling =0
