Hi - my VY Berlina LS1 makes a slight noise like a sqeaky / creaky whine when turning the steering wheel at low speed, eg in carpark. Feels like resistance due to a dry bush in the steering shaft or similar. Any one else with same issue? Thanks
i have the same issue. I've read somewhere that it has something to do with the pressure in the power steering pipe and if you get a bigger one it will fix it. I haven't done this but any additional advice would be good.
mine makes more then just squeaking it shudders and what not, i went to about 4 places and they all said the top of my struts (bearings) have gone due to not putting shortend shocks in.
Thanks guys - the fluid is OK. I have had the tubes done when the car was under guarantee. It really feels like a bush in the column or something is tight. The manuals show that the whole column gets replaced - it is non-servicable.
