cruise control-blinkers???
ianf
Lansvale NSW
99 VS 'S' Utility
:cry:Can someone maybe point me in the right direction?
Anyone who knows me knows I am hopless with anything mechanical, This time however I am clueless?
For some reason my cruise control is not working. I checked the fuse but it's fine but I have noticed that at the same time I lost my cruise control my blinkers stopped turning themselves off after rounding a corner. They sometime turn off and you can hear the clicking and I wanted to know if this might be the cause of the cruise not working?, and if not, what else should I look at?, I'm driving a 99 S ute. Thanks...:dance:
accentstencil
68
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
I suspect the indicator stalk may be the problem.
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
As above - maybe the indicator stalk has been dislodged from it's mount - you can drop the panel under the steering wheel to access the switch mount. Disconnect your battery first!.
ianf
Lansvale NSW
99 VS 'S' Utility
Is there anything else I should be looking towards in relation to the cruise control?, I did as you said but couldn't see anything that really seemed out of place?
accentstencil
68
Eschol Park, Sydney
Are the cruise control controls on the indicator stalk? I can't remember.
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
The cruise won't work if a stoplight bulb is blown, or one of the two brake switches are out of adjustment or relay is not working. Does the cruise light come on?
ianf
Lansvale NSW
99 VS 'S' Utility
Cheer's, you were spot on!, it turns out it was a stop light that had blown and as soon as I replaced it the cruise was fine, thanks again...
