Cruise Control drops out at 30klms per hour - CV8 Series 3
Deuce
Super Stock
'94 VR SS V8
What other driver aids are present on your car? Other than ABS.
As it sounds to me like once you are 30+ something is sensing an issue and taking that parameter offline, such as a wheel speed sensor etc.
Tyre pressure monitor? Yaw control? Traction control etc etc.
Lutz
62
Newcastle
CV8 Series 3
Hi, it has traction control. Not aware of anything else?
Skylarking
123
Downunder
Commodore Motorsport Edition
Any fault with such features (ABS, ESC, TC, etc) would, you’d think, result in a DTC and potentially a warning lamp but yo said you got nada :oops:
BlackVXGTS
Melbourne, SE
The attached may be of assistance to you in diagnosing your problem:
  • VY Cruise Control Diagnosis.pdf
Deuce
Super Stock
'94 VR SS V8
Check your tyre pressures are even.
Actually, any chance you have fitted a staggered wheel combo lately? That could cause issues.
Also have a look at wheel speed sensors to see if anything unusual is visible on 1 corner.
Lutz
62
Newcastle
CV8 Series 3
Hi, thanks for the attachment... This guide should be a Sticky Note?
I went through the self diagnosis procedure and the Electrical Release Switch in step 9 failed. I have ordered a new one. I'll report back when its replaced. There may be more problems but I cant test the rest untill i fix step 9 :)
Thanks again.. :)
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
Thanks again.. :)
Is that switch the brake pedal switch that cancels cruise control, when the brake pedal is pushed?
figjam
Donating Member
Far Kurnell
FJ
Memory bank ........... that apparently was a fault with early Ford Territorys. An incorrectly fitted brake booster rod was activating the brake lights intermittently and cancelling the cruise control .............. I think.
  • Like
Reactions: Lex
Lutz
62
Newcastle
CV8 Series 3
Yes.. thats the one… its located above the stop light switch
Lutz
62
Newcastle
CV8 Series 3
Nothing surprises me on a ford territory…
