cruise control issue!
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by mrVT, Apr 16, 2013.
  1. mrVT
    mrVT Guest
    ok afew days ago on my vt my indicator/cruise control stalk **** itself and I purchased a new one all installed ok, today realised that I put cruise on button it lights up on cluster but for some reason the active button once pressed wont light up on cluster I don't think the stalk is faulty cause everything else works ok so what could be the problem here? I did have an abs module problem but don't think this would affect the cruise control motor!
  2. Deuce
    Deuce Super Stock
    '94 VR SS V8
    the 2 things I know:
    1) cruise control will not activate under 40kph,
    2) Brake lights deactivate cruising, so does a blown bulb.
    please check your brake lights, as it would suck if a $1.20 bulb caused all this headache.
  3. Mad84VK
    Mad84VK New Member
    VY S Ute
    my vu does the same thing. i turn on the cruise control and it lights up on the dash, then i go to set and doesnt work. lights are fine :\
