Cruise Control on VY One Tonner without Cruise Control
Discussion in 'VY Holden Commodore (2002 - 2004)' started by Joshua92, Nov 23, 2012.
  1. Joshua92
    Joshua92 New Member
    Gordonvale, QLD
    2003 VY One Tonner Series II V6
    Hi folks
    I'm only new to the forums here. I have googled a heap of stuff in terms of cruise control on any VY Commodore. My One Tonner however does note even have a module there to start with. Has anyone else been in this position before and installed cruise control in their VY that had no module? Is everything done from scratch, or does it still have loom?
  2. edals
    edals Well-Known Member
    Here
    VE Equipe
    Hey Mate, Check for this plug in the engine Bay, it will be tucked up under the massive loom, if you find it yes you can install cruise control, you will need
    Cruise Control Module, Cruise Control Throttle Cable, Throttle Body Cable Linkage to support both Throttle Cables, Brake Switch & Cruise Stalk.
  3. tyrefryer
    tyrefryer New Member
    Commodores!
    If you dont have that cable, it is still possible most of the time, you just need to patch the wiring into the BCM and may need to enable it via tech 2 programming
