Hi All, I've located a dismantler who will sell me a complete cruise setup for my VT V6 for a good price, but I just need to confirm the actual parts required and if my car is even suitable for it: Cruise module (with mounting bracket) Cable Brake pedal switch Indicator stalk Relay Is there anything else required? Should the wiring already be there or is there a patch cable required? My Haynes manual also mentions a transducer located on the inner fender though I can't see anything to fit that description. Another thing is that I got down under the steering column to see where the brake pedal switch would go. There is a hole in the mounting bracket above the brake light switch, but I could not see, nor feel any plug or wiring for the cruise switch, does this mean that my car is not suited for cruise? Thanks for the help.
Wiring may or may not be there. Pull the plastic covers on top of your steerling wheel off the see if they're there. Or check near the right strut tower to see if there is a wire there. I've got a VT Cruise wiring harness if you need one, brand new. Send me a PM if you need it.
