Cruise control problems
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by CANYONERO, May 13, 2008.
  1. CANYONERO
    CANYONERO Likes Cheese...
    Country SA
    V8 6spd wif MOMO leavaa.
    It had to happen now because im selling it :bang:
    the other day my cruise control just stopped. one day it was working fine, next day nothing. it will turn on (green crs light) but wont activate (yellow light) i've checked the connections and all seem fine and cables dont seem to have come adrift or anything and the fuse is ok. i have done nothing to the car to affect it to the best of my knowledge.
    oh and my batt died this morning, so i was late for work. more money. if this keeps up im going to have to pay someone to take it!
    anyone had this drama?
  2. Surfwagon
    Surfwagon Well-Known Member
    Sydney/NSW
    AMG Mercedes C63 Wagon
    Are you sure that the CC isn't actually working or just the yellow warning light not working.
    I've had to replace the Power, CC active and CC on/off globes a couple of times in the 10yrs I've had mine.
  3. CANYONERO
    Country SA
    nah its def not working, i've replaced the globes before. the car wont cruise.
  4. bunzmc
    bunzmc New Member
    VS Commodore Wgn '96
    I've got the same problem.
    One day out of the blue it just stopped working.
    My cruise control turns on but when I try to set the speed nothing happens.
  5. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    Have you checked the switch on the brake pedal. Also does the switch feel ok, not sticky or lost its spring ect.
    Also i have never actually played with the cruise, but you can normally heard a relay click in when its set. Try checking that relay, it may have a burt out coil or dicky contacts ect. Failing that maybe try a second hand control arm, can usually pick them up on ebay cheap.
  6. bunzmc
    bunzmc New Member
  7. CANYONERO
    Country SA
    i do get the activation click when i turn it on (green light) might check the brake switch, i was thinking the stalk might be knackered.
  8. Fekason
    Fekason Fekason
    Penrith NSW
    Agree with checking the brake micro-switch.
    I have experienced the same problem on a VS II manual that I had (son now drives). It was the micro-swich on the clutch pedal.
    It was not a switch failure, but a movement of the switch mounting such that the switch was dis-engaged even when the clutch pedal was released.
    The setup on the brake pedal is the same, so I would check that first, followed by checked the micro-switch itself.
  9. VrWagz1
    wollongong
    If you are getting the activation click and green light, then i would assume the cruise is working as intended. I would be inclined to check where the cruise connects onto the throtle body as it sounds as if it has become un attached from it. Post us if you find the problem
  10. ephect
    ephect Donating Member
    VS Acclaim V6
    seams left of field, but have you changed your rear globes to leds lately?
  11. Chirpstr
    Chirpstr A new project attack
    VR Berlina M5, VP M5
    I had this exact problem. Battery died hey. I would put money on the alternator regulator about $40 bucks to fix. Black thingy on the back.
    When this goes the battery surges causing the computer to glitch I'm pretty sure...
    When my cruise played up, one of the cruise lights went out then it was just free revving until red luckily I stopped it just in time from hurting the motor by turning the cruise off completely. I think I either tapped the brakes or switched it off on the stalk. Anyway I don't know if this is your problem but I can only state what happened to mine.
    Do you get a battery light up on the dash?
    It's either your Regulator or Battery. Could be the cruise module but I doubt it. Both can play silly buggers with your cruise and who knows what!
    Good Luck Mate.
  12. DJ Ice
    DJ Ice Member
    Gold Coast
    MY07 VE Calais V
    Have a close look at your indicator switch towards the bottom and check for pinched or cut wires (They are the thin ones which go to their own connector) which is fairly common. I had that issue and replaced the indicator switch for a new one off eBay for around $60 and it now runs fine.
