Cruise Control
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Turd Ferguson, Aug 21, 2008.
  1. Turd Ferguson
    Turd Ferguson Donating Member
    N.S.W
    Disco
    I'm having problems with the cruise control in my vp calais, maybe its me not knowing how to use it or its broken.
    O.K, So i get to my desired speed (60) and i press the cruise control on/off button and the little green light on the button comes on, i take my foot off the accelerator and it starts losing speed and then wont speed back up.
    Should a light come on the dash or anything when CC is on and is their anything else i have to press that im not doing?
    Thanks guys.
  2. vnv8driver
    vnv8driver Banned
    Up your mum
    304 Calais
    press the on button, then press the + once and it will maintain speed. hold it down until you reach 100 or so, then release it.
    you can accelerate and it still stays activated, but as soon as you put the foot on the brake itll turn itself off.
  3. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    The light comes on in the dash (CRS) when the electrical side is working.
    I'd check the cable.
  4. FXST01
    FXST01 The Grey Man
    Perth, WA
    VP V6 Exec
    After the green light is on, I press SET (-) to engage the Cruise control and then CRS light comes on. When cruising and it comes off, press RES (+) to re-engage it.
  5. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    You need to turn it on so you see the green light. Look carfully at the buttons and one is called "set-coast". Press it and the orange light will come on the dash and it is now set.
    If you want to speed up, press the "acc-reset" button while on cruise. If you press the brake to slow down, the want to reset the cruise to where you were before, you can simply press the "acc-reset" to reset the cruise to where you were.
    Hold down the "set-coast" button to slow down while on cruise.
  6. 88GreenVN
    Surprise, Arizona
    Just read your post again. Hmm. Um the little green light is when the CC system has power. (I read it as you were pressing the set button and the CRS light was on but the car was loosing speed) as in not engaging.
    When you press the set button the CRS light comes on where the warning lights (indicators & high beam lights) are.
    When set and CC is active you use the + or - to adjust speed. "tap" the button once should give a 1kph change up or down in speed. Press and hold the + or - will let the car coast to the required speed.
  7. Turd Ferguson
    N.S.W
    Disco
    Ya the light that is built into the on/off button comes on but i dont see any crs button on the warning light part come on, will give it a shot again today
  8. vnv8driver
    vnv8driver Banned
    Up your mum
    304 Calais
    Its not hard press the ON button, then press the plus or minus to activate, preferably the plus, then keep it held down to increase speed, if it doesnt work then theres something wrong
  9. burnz
    burnz dah dut dut da dah
    springfield
    VFII SS ute M6
    put your foot on the brake and see if your parker light's on the front light up.
    if so replace brake light globe.
  10. vnv8driver
    vnv8driver Banned
    Up your mum
    304 Calais
    burnz ive come across that problem before and what i did to fix it was put a new plug/connection to one of the front headlights and it fixed the probem, it was an earth problem.
  11. Turd Ferguson
    N.S.W
    Disco
    Forgot about this thread...
    but yes CC in my calais doesnt work, not sure what it could be, i will replace fuses but if that doesnt help what should i do? are Holden able to repair it? if so how much would i be lookihg at
