Custom air filter affecting LPG?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by frogsta, Oct 17, 2011.
  1. frogsta
    frogsta Sleeper
    Mazda 6 MPS 2.3L Turbo AWD
    Hey guys, my mate's a mechanic, and he's saying that my custom pod filter could be a cause for my LPG stalling. (Spark plugs have been replaced, but I haven't serviced in a while).
    Just wondering your opinion? He's a Ford fanatic, so he could just be biased and whatnot.
  2. VrWagz1
    VrWagz1 The Wagon on Wheels..
    wollongong
    VE SSV MY09 Auto Wagon
    IMO no, shouldnt affect things. But if u have a venturi system i spose there is the possibility it could affect it but i wouldnt think so.
  3. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Unless the pod is blocked, it won't affect it in the slightest. Get the mixtures redone and it should be good.
  4. frogsta
    frogsta Sleeper
    Alright, how do I get the mixtures redone? Just get it serviced? Not good with cars.
  5. goose202
    goose202 New Member
    VX Calais LS1, SY Territory Ghia
    What type of LPG setup is it? Does the LPG setup have a "balance" line? Ie a line that goes from the back of the converter to the airbox?
    If it does, then I'd say your mate could be right, but I'm certainly no LPG expert. I had a Falcon on LPG with this setup that was really touchy on leaks for the balance line, symptoms were massive flat spots when taking off from the lights.
  6. darcycammo
    darcycammo Member
    Cockatoo Vic
    Did have VS Berlina now have VT Berlina
    I have the same set up on my VS and i was playing around with it one day and forgot to put the hose back on and it wouldn't work on gas
  7. frogsta
    frogsta Sleeper
    It's dual fuel, no liquid injection. Not sure about this balance line. Just gonna get it serviced and see how it goes from there.
  8. woteva
    woteva NEED 4 SPEED
    Adelaide S.A.
    Get the gas serviced and they should adjust the mixtures for you. Seen it done before where they stick a probe up the exhaust pipe and check the levels.
