smokey
Hey guys, I'm looking at building a custom centre console for my VG ute, It's a column shift auto with VS buckets in place of the old bench seat.. What I'm going to do is swap the standard ute centre dash panel and stereo surround for the one out of a wagon so that the standard centre console will meet up with the dash properly.. Then comes a bit of cutting and shutting, I'm going to cut the back half off where the arm rest is and replace that with an 8 litre waeco or engel fridge and fibreglass it to the front half of the standard centre console.. Then I will fibreglass over the hole where the floor shifter would normally go and where you would find the hand brake in a sedan.. Holes will be cut for 2 4" speakers that will be mounted side by side in the front section of the console, then it will all be painted along with the bottom half of my dash, glovebox, fuse box cover, etc. I'm wondering if anyone can see any problems that I might come across? Or any suggestions would be good.. cheers
