Blackwolf101
- Oct 27, 2018
- 82
- 46
- 18
- Age
- 38
- Location
- Perth, WA
- VS Senator 215
If you're handy with things and confident, find the alarm box (should be somewhere above the pedals in the dash) pull it down and carefully open it up, check the circuit board around the relays that are actually mounted on that circuit board to see if there are any loose connections (you'd need to look for tiny cracks on the soldered parts) if you find any then you'd need to re-solder them to fix this (with battery disconnected). I've worked with immobilizers for many years and 9 times out of 10 when the engine was cutting out, it turned out to be just that.. it's very common!
If you are going to be doing this, and you have rings or chains on your hands then remove them, because if they come in contact with any part of the circuit board you could fry the alarm. Or just disconnect the car battery, just the negative clamp is enough. You could also take some pics, i would know more what you have there then.
Joining the pink wire back together as i've suggested earlier will just by-pass the relay in the alarm which may have the loose connection on the said circuit board.
